Midi Control for Manual Trigger ? Topic is solved
dariusdark
Post by dariusdark »
Hi, I've got problem - I want to use Manual Trigger with MIDI protocol. Simply, external midi signal would have the task to change following scenes in sequence just as the manual trigger does. Is it possible?
dariusdark
Re: Midi Control for Manual Trigger ?
Ok, never mind - it's simple ;)
