One moving head starts at same position during sequence!
mrgordon27
- Just started using FS
- FreeStyler Version: 3.5.5
- Twitter: twitter.com/djsolstice
Hi all. I have two moving heads (China brand). When I play them to a Bezier shape all is well. But when I recall that shape in the sequence/cue window, one of the moving heads points up to the ceiling before starting its path. It's not the DMX signal because I put a terminator and tried different cables. The other unit father on the route is fine and doesn't do this. It's not the unit either because I switched the channels on them and that didn't fix it, the other started doing it. It has something to do with the fact that it's Inversed pan and tilt. When I press the button to run the sequence it's like it's trying to reset a position or something. Never encountered this before. HELP!!!
- buttza
- FreeStyler Version: 3.6.4
Re: One moving head starts at same position during sequence!
Check the starting channel is correct.
Also reset the lighting fixture then re channel.
Which way is the base and yoke facing by default?
