Hello my friends can you help me please ?
.pff file fixture to this light pot ?
Fun Generation LED Pot 12x1W RGBW
Do anyone have already ?
Technical specifications:
Light source: 12 Piece 1 W TrueColour LED - 3x Each of red, green, blue and white
Beam thomann angle: 25°
Light output: 5520 Lux @ 1 m
Dimmer: 0 - 100%
Strobe effect: 0 - 20 Hz
DMX input and output: 3-Pin XLR
Power supply: 100-240V AC, 50-60 Hz
Max. power consumption: 15 W
Protection class: IP20
Ambient temperature: -10 ° C to + 40 ° C
Dimensions (W x H x D): 168 x thomann 172 x 130 mm
Weight: 0.76 kg
Fun Generation LED Pot 12x1W RGBW .pff file
TOZESURF
- FreeStyler Version: 3.5.7
- FreeStyler Version: 4.1.7
Re: Fun Generation LED Pot 12x1W RGBW .pff file
I'll be glad to help you. I could not find any information about the DMX channels this instrument uses. Can you either post a link to the manual, scan the channel chart to a PDF, or even take a clear picture of the channel chart or even simply type the channel usage in a post. I can guess but I will probably be wrong.
TOZESURF
Hello my friend . Thanks for the help
See what i´ve got
Number of DMX channels depending on operating mode 4, 6 or 8,
7.4 Functions in 4-channel DMX mode
Channel Value Function
1 0…255 Intensity Red (0 % to 100 %)
2 0…255 Intensity Green (0 % to 100 %)
3 0…255 Intensity Blue (0 % to 100 %)
4 0…255 Intensity White (0 % to 100 %)
7.5 Functions in 6-channel DMX mode
1 0…255 Dimmer (0 % to 100 %)
2 0…255 Intensity Red (0 % to 100 %)
3 0…255 Intensity Green (0 % to 100 %)
4 0…255 Intensity Blue (0 % to 100 %)
5 0…255 Intensity White (0 % to 100 %)
6 1…255 Strobe effect
7.6 Functions in 8-channel DMX mode
6 0 Blackout
1…16 Activate colour macro for channel 7
17…33 Programme 01
34…50 Programme 02
51…67 Programme 03
68…84 Programme 04
85…101 Programme 05
102…118 Programme 06
119…135 Programme 07
136…152 Programme 08
153…169 Programme 09
170…186 Programme 10
187…203 Programme 11
204…220 Programme 12
221…237 Programme 13
238…255 Sound control
7 (if channel 6 is in colour macro)
0…15 Colour value R = 000 | G = 000 | B = 000 | W = 000
16…31 Colour value R = 255 | G = 000 | B = 000 | W = 000
32…47 Colour value R = 000 | G = 255 | B = 000 | W = 000
48…63 Colour value R = 000 | G = 000 | B = 255 | W = 000
64…79 Colour value R = 000 | G = 000 | B = 000 | W = 255
80…95 Colour value R = 255 | G = 150 | B = 000 | W = 000
96…111 Colour value R = 255 | G = 180 | B = 000 | W = 000
112…127 Colour value R = 255 | G = 255 | B = 000 | W = 000
128…143 Colour value R = 255 | G = 000 | B = 255 | W = 000
144…159 Colour value R = 255 | G = 000 | B = 140 | W = 000
160…175 Colour value R = 000 | G = 255 | B = 255 | W = 000
176…191 Colour value R = 255 | G = 000 | B = 000 | W = 210
192…207 Colour value R = 000 | G = 255 | B = 000 | W = 210
208…223 Colour value R = 000 | G = 000 | B = 255 | W = 210
224…239 Colour value R = 255 | G = 200 | B = 040 | W = 090
240…255 Colour value R = 255 | G = 255 | B = 255 | W = 255
7 (if channel 6 is in a programme 1– 14)
0…100 Speed for programmes 1–14 of channel 6
101…255 Intensity Sound to Light
8 1…255 Strobe effect
See what i´ve got
6 0 Blackout
17…33 Programme 01
34…50 Programme 02
51…67 Programme 03
68…84 Programme 04
85…101 Programme 05
TOZESURF
This fixture file is for the 6 channel configuration.
Note that Colors window does not include the White (amber in the Fixture Creator definition) channel when you use the color mixture on the left side of the Colors window. You can adjust White by using the CTO slider on the right side of the Colors window.
I will also build the 8 channel configuration. That will take a little time.
TOZESURF
My friend thank you very much.
When you need something i´ll be glad to help you also .
This is my attempt at the 8 channel fixture configuration.
In your post with the DMX channel values a value of 0 for Channel 6 is listed as Black Out. I hope that really does NOT mean black out in that the fixture lamps are turned off but rather that the values in channels 1 thru 5 control the fixture lamps.
Once you import the fixture file and add the fixture to Freestyler select it and click on Window and then click All. In addition to the sliders window on the upper right of your display screen you should see 4 windows: Lamp, Custom Sliders, Colors, Macros.
Keeping in mind the above black out comment you will see a black box as the first macro. This macro will set channel 6 to 0 which, hopefully, sets the instrument to be controlled by channels 1 thru 5 and 8.
In the Macros window the macros in black boxes with the numbers 1, 2, 3 ... 13 select the programs built into the instrument. The Custom Slider Speed for Programs will then control the program speed.
Again in the Macros window, the Sound Mode macro will set the instrument to react to sound and the Custom Slider Intensity Sound to Light will control this function.
Now take a look at the Colors window. There are two tabs; (1) Fixed colors and (2) CMY - RGB.
In the Macros window click on the black box (the first macro). In the Colors window click on the CMY-RGB tab. This should allow you to use the Dimmer channel and the Red, Green, Blue, and White lamps via the color mixture pallet and sliders in the Colors window. Note that in the Colors Window the white channel is controlled by the CTO slider - the mixture pallet does not change this channel. In the Slider window in the upper right of Freestyler the white channel is labeled Amber.
In the Macros window if you click on the rainbow macro this will disable channels 2 thru 5 and enable the fixed color selection in channel 7. In the Colors window click on the first tab (Fixed colors). Clicking on one of the color blocks will cause the instrument to display the predefined color.
NOTE - The colors in Fixed Colors block are the best I could match to the values listed in your post. The ones with the white channel set to 0 are only a guess on my part as the color pallet assumes amber, not white. I could be, and probably am, way off.
Sorry for the long post but this is an interesting fixture with quite a mixture of function.
When you have the time please test your instrument with this fixture and let me know how it works. I am willing to make changes if needed.
Good luck and have fun.
