I can't believe I've been gone 4 years! The band ended, the new band didn't need a light guy, the acoustic band only required a few led pars on fade. Things look like they might be happening again, and I have 4 trees set up in my basement right now while I try to remember Freestyler! I backed up my ver 3.4.0 files, so everything I created before is here and working (in virtual, one led par won't turn on
I bought a Matrix 4-channel double output DMX dimmer pack right before my light job stopped.
I was using 2 trees of LED pars (RGBA Blizzard pucks) with Freestyler. I have 6 incandescent par cans that I'd now like to use on the DMX system. Then I'll use these dimmer pack pars in front and the LEDs in back of the band.
There are some stages so small that I'll revert back to only my 2 trees of LED pars.
What is the proper way to handle things when the layout or usage of different lights is different? Should I just add everything to the main screen and turn off what's not being used?
It's basically just 2 scenarios. All 4 trees or just the 2 LED sets. I'll do some reading here on setting up my parcans in Freestyler.
Thank you!
It's good to be back
