"StrobeOff" button missing from TouchUI
jsspro
Post by jsspro »
Hi.
The strobe off buttons are missing from the touchUI button list. (or I can not find)
Please put it into the list if possible.
And I have a little problem. (TouchUI)
If I slelect first RGBW lamp (led par, led moving head) after select not RGBW (strobe, simple moving head,....) the rgbw value will be reserved. The slider upper position will be 0 lower position will be 255.
If I select first no RGBW lamp for examle strobe after select RGBW lamp the position value is correct.
This is confusing beacause if I push "select all button" the rgbw slider position value will be reserved.
I tried to choose fixture the original list but it is also bad. I do not know whether the fixture is defective or the program.
Thans for the help.
Christian
Re: "StrobeOff" button missing from TouchUI
Post by Christian »
Why you don't create a scene to switch the strobe off and put it on a button?
For your 2nd question: Please post a screenshot to analyze the problem.
jsspro
Post by jsspro »
Christian thanks for your reply.
1nd strobe off button
If there are strobe low, mid, high why isn't off (on touchUI)? it is easier than create scene
http://www.kephost.com/image/vxPf
2nd reversed/invert value problem
NOK:
http://www.kephost.com/image/vxP1
OK:
http://www.kephost.com/image/vxP5
Thanks a lot
Christian
Post by Christian »
Ok, now I understand. You mean the value is "inverted"? Please use the bugtracker and upload the pictures for illustration. For the strobe button, open a second ticket as a "feature request".
jsspro
Post by jsspro »
Thanks.
I sent this bug with bug tracker.
lightman1990
FreeStyler Version: 3.6.3
Post by lightman1990 »
I also wonder why there is no "strobe off" button in touchui...
MrSleeps
FreeStyler Version: 4
Post by MrSleeps »
You can do what I did and create a strobe off macro that sits on the lamp panel.. Clunky workaround but it works
Return to “Ideas and Remarks”
