I can't get my freestyler to output any artnet. I disabled firewall and antivirus and i start freestyler with admin rights on windows 10 64bit. I set the Net=0 Sub=0 and Uni=1 and i select my network then leave X.255.255.255 and try but no output is beeing sent also everytime i change a value in either Net, Sub or Uni freestyler crashes. I am using 3.6.37. I know Artnet works because DMX workshop finds my node and i can transmit to it.
What am i doing wrong in Freestyler ?
/donnib
No artnet output from Freestylerm why ?
donnib
kittmaster
- Commited FS Forum helper
- FreeStyler Version: 3.6.2
Re: No artnet output from Freestylerm why ?
I ran into this one time also, when it works it works, when it doesn't it's a pita.
Your subnet universe, are the limits 0-15 on the node or 1-16? Make sure you map to the right offset.
Also, be sure to follow the syntax of the subnet mask of x.
When i was using 2.0.0.1 for the computer and 2.0.0.2 for my art-net node, I had to input the subnet mask as 255.x.x.x, for some reason 255.0.0.0 wouldn't work, reason unknown.
See if any of that can help you on your way.
