Custom tempo tap by small external program
sjaakthomassen
Just started using FS
FreeStyler Version: 3.3.2
I Use FreeStyler for: Band
Post by sjaakthomassen »
Hi all,
Love freestyler, just always have been struggling with accurate tempo tap.
Decided to make a small external program to try and fix that.
Maybe it can help you as well.
Regards,
Sjaak
fs tempo.png (17.34 KiB) Viewed 318 times
FS tempo.zip
(154.59 KiB) Downloaded 31 times
barrypearce
Re: Custom tempo tap by small external program
Post by barrypearce »
Thanks but this does not work at all for me. Instead it toggles the "favourite". A couple more clicks and it crashed. :(
sjaakthomassen
Indeed it toggled 'favourites' as well. Removed that and made an installer, hopefully that takes care of a decent install.
sjaakthomassen
Oh, and note it triggers the manual tap, not the internal freestyler sync tap. That means you don't see anything until you start playing a cue
Return to “Ideas and Remarks”
