Adding a relay pack
directsound
Adding a relay pack
Post by directsound »
When I added a relay pack in fixture creator I made 4 CH item and add names of each ficture hanging off each channel. when I went to the sliders it was hard to go to full on because these lights ar on or off only is there a way to make them just switch them on and off like 0 to 255 only? also when i added it to the DMX 400 it will add all 4 ch at once so do I need to make relay packs one channel at a time? Thanks Dj Mikey Mike :) :)
Android Dev (Moderator)
FreeStyler Version: BETA
Re: Adding a relay pack
Post by Mattotone »
in fixture creator assign the shutter open close to the channel open 255 closed 0.
Make this a single channel fixture and use one fixture for each channel.
directsound
I got that but is there a way to just make an on off button instead of using the slider?
Thanks Mikey Mike :)
8 Overides on off on off etc....
better still 8 ON overides set to flash then mapped to keyboard cause the default is off i guess
directsound
Sorry i didnt under stand 8? :(
8 as in 4 on and 4 off settings then i changed my mind and meant to say just 4 ON!
directsound
Sorry I still dont get it maybe I will need to refrase it. let me think about it for a bit and give Freestyler a hack againe!
Thanks Mikey Mike ;)
Post by Mattotone »
open and closed shutter is a little like an on off button.
Post by Mattotone »
To make dj supports idea a little clearer.
Instead of creating a new fixture profile.
For each channel create a new sequence that just has the channel at full.
Save the sequence and add it to the overrides buttons.
Pressing the button will turn the channel on, pressing it again will release it ~(off)
Mattotone wrote:open and closed shutter is a little like an on off button.
exactly im always a 6 word writer
directsound
Got it! Sweet, thanks!
Mikey Mike
Directsound do u have wlm/msn? aend me ur addy
