Eurolite tmh-14 Topic is solved
agire.teatro
Eurolite tmh-14
Post by agire.teatro »
Does anyone have a fixture file for this moving head?
I'm also looking for it
thanks
FreeStyler Version: 4.1.7
Re: Eurolite tmh-14
Post by Rod_Horning »
This may work but I have no way to test it.
Feedback appreciated.
I've included a few custom sliders so you'll probably want to click on Window All after you select the device. You may need to move a couple of the windows as they may appear stacked.
