Hi all!
I'm requesting the fixture file for my Showtec mobinghead.
I watched different video's and websites but 'm still not able to create a fixture .
Can someone help me to create a fixture file for my movinghead?
User manual: https://goo.gl/aUiq8F
DMX channels (16 channels) are on page 19-20
Showtec XS-1RGBW
- FreeStyler Version: 4.1.7
Re: Showtec XS-1RGBW
I did not see a white channel in the fixture creator so I used the amber channel.
After you select the fixture you probably will want to click on Window and then click on All.
I did not set up any macros but a few macros might make remembering the settings for channels 6 8 10 15 easier. Let me know if you would like me to give this a try.
I hope this helps and would appreciate any feedback.
Regards
Regards
- FreeStyler Version: Beta
Hej.
Please use the Export function in Fixture Creator.
It packs images, gobos and much more into a pff file and when you import it then it is placed in the right folders again.
This is the proper way to exchange fixtures and also the reason for the blocking of fxt file upload.
OK. Thank you for the info.
Original post edited to delete the 2 files and attach the Exported fixture file
Jinte
Thanks a lot!!
Aprreciate it!
Works fine on the first use, thanks!
If I can do something for you, contact me!
Aprreciate it!
Thank you for the feedback. Glad it worked!
