Feature requests Topic is solved
abyssdj
Feature requests
Post by abyssdj »
Do these ever get acted upon? I'm finding myself having to create awkward workarounds all the time and the suggestions have been "under consideration" since March.
http://www.freestylersupport.com/bugs/view.php?id=1299
http://www.freestylersupport.com/bugs/view.php?id=1300
http://www.freestylersupport.com/bugs/view.php?id=1301
abyssdj
Re: Feature requests
Post by abyssdj »
I'll take that as a big fat no, then?
One man makes this software, for every bit of code comes multiple other potential conflicts, you just have to be patient, if not go pay for something you do want!
Post by Jan_K »
You are a bit right when you say nothing is happening when it is "under consideration".
I think the only time he looks at these suggestions is when he are to redesign the part of the code where the suggestion have an impact.
Also I think that most of the time goes firefighting as this is a complex software where even a small change have influence at many instances.
And it takes for ever to make a 100% test for one man.
