Easyview and Freestyler on seperate screens. Topic is solved
pheonixtech
Post by pheonixtech »
Hiya.
Basicly I was wondering if it is possible to connect 2 monitors to a PC and display the FreeStyler window on one and the EasyView window on the other.
Sorry if this is a bit indescriptive.
Thanks in advance 8-)
Alex
Re: Easyview and Freestyler on seperate screens.
yes its possible because if you set windows up to 'Extend desktop onto this monitor' then you drag the easy 3d view to the other screen,
It works like one looong desktop you can drag any windows on to the other side.
pheonixtech
okey doke. Thanks for that.
