Hello everybody!
I have new user but I have some perception.
I use Touch UI no mouse and no keyboard control.
Should Touch UI button:
- ’Label’ button, empty function - simple label function
-’Strobe OFF’ button
- ’Fixture xx’ button „Fixture1, Fixture2,…”
-’Fixture Intensity’ button 0% and 100%
-’Full 0’ or ’reset’ button. If fixtures are selected I push „full 0” only selected fixtures channel value it would be 0.
Ideas and necessary function:
-’DMX 400 off’ function when the channel value (color and intensity) will latest fixture channel value.
If I run dmx400 after I push static mode the color and intensity is remain.
-White channel should be color mixing RGB table. On the Color table over the horizontal center white channel will above. Under horizontal center white 0 and RGB is fewer. ( So it would be vertical axis white channel. Center is 0 thence up the value increases)
-I don’t see if macro function is active only from output channel value.
Should feedback if the value is not 0.
-There are a few key witch lighting when I push but not need. Master Intensity 0%, Master Intensity 100%, Master Fade time +/-5%......
These buttons should be lighting as long as I push (Strobe lo-mid-hi, Master intensity 0%,100%...).
Bug or features?:
-All group is selected the RGB channels sliders jump up and the slider up position value will 0 and the slider down position value will 255.
-The main side Shutter value no equal Touch UI side Shutter value.
If you pull down Touch UI Shutter the main side Shutter get stuck 3,4,5 % random (output value is correct).
-Touch UI Master Intensity no follow the main side Master Intensity slider.
O% and 100% is OK but Fade In and Fade Out do not go slow only jump up or down.
-Multi CUE. If I run 2 or more sequence the all latest sequence value will 0.
I thought, I can run more sequence on cue list at the same time. But No because step is run but output value is 0.
Sorry for the grammar mistakes
3.6.36 some perception
