Fixture File Blizzard Torrent F3 Topic is solved
clubtproductions
Post by clubtproductions »
I wanted to see if someone could please make
a fixture file for the Blizzard Lighting Torrent F3 moving head spot please.
http://www.pssl.com/c/Manuals/TORRENT-90-SPOT.pdf
Thanks for your time.
Tommy Walsh
:fs:
TORRENT-90-SPOT.pdf
(3.27 MiB) Downloaded 17 times
Kmeist88
Re: Fixture File Blizzard Torrent F3
Post by Kmeist88 »
Did anyone ever make a fixture file for these f3s?
FreeStyler Version: 4.1.7
Post by Rod_Horning »
If no-one else has one give my attempt (attached) a try.
If you try the attached please feed back the colors and gobo positions. With that information I can improve the fixture.
Once you have added the fixture to the Freestyler workspace and selected it, click on the top menu item Window -> All. This should open the following windows:
Gobos - I can add pictures if you feed back what gobo is assigned what dmx value
Beam
Lamp
Custom Sliders
Colors - this can be improved if you feed back what color is assigned what dmx value
Pan/Tilt
Feedback and/or questions are welcome.
Blizzard_Torrent F3.pff
(76.3 KiB) Downloaded 16 times
Kmeist88
Post by Kmeist88 »
Thanks! I don't know if I will get to play with it this weekend or not but I will be sure and get back to you when I do
