PAR64 led from China, which fixture ? Topic is solved
donnib
Post by donnib »
I have this fixture from Aliexpress : https://www.aliexpress.com/item/18X3W-L ... 0.0.uWlvyf
The document says 7 channel, i tried to take a normal fixture and enter channel 2 Red, 3 Greene, 4 Blue and 1 Intensity but it messes up the color, for some reason i am not sure how to use the other dmx channels what they correspond to in Freestyler.
I would appreciate some guidance if possible,
thx
donnib
A3aanKeij
Re: PAR64 led from China, which fixture ?
Post by A3aanKeij »
Sometimes AliE DMX charts don't match the fixture. To find out which channel has what function simply make a 1-2-3-4-5-6-7-8-9 ch fixture and test to find out which channel does what when sliding 0-255. Kind of reverse engineering... Takes time, but you sure get to know Freestyler!
A3aanKeij
Post by A3aanKeij »
I have a different chart 18x3Watt. Btw: it's not really a 54Watt fixture, don't try to adjust the power, you'll blow it.Image
