I'm running 3.6.34, I added a bunch of static programs like simple on off toggles of fixtures. It seems I can only select one at a time. Shouldn't I be able to multiple select those buttons as a master override as to what is attached to each button?
Right now, it seems like I can only select 1 and only 1 at a time.
I don't see a multi-select option in the gear icon.
Thanks.
Programmable Override Buttons
kittmaster
- Commited FS Forum helper
- FreeStyler Version: 3.6.2
- FreeStyler Version: 4.01
Re: Programmable Override Buttons
Make sure the other fixtures are not included in the sequence.
Christian
a button that contains the same channels as another button disables the previous button. Different channels of the same fixture or other fixtures can be switched simultaneously with different buttons.
kittmaster
Hmm, I'm trying to fire dual pars in 11 channel mode at channels 1 and 12 | 23 and 34 as either/or or both using the overrides......I guess I'll just have to do it as sequences and route them via unique cue buttons.
TY.
TY.
