Hi
Is it possible to use an EnTTec Open DMX USB connected to the router USB port and send the data wireless????
Many thanks from Portugal!
Using Router USB Port
peixotolopes
- FreeStyler Version: 3.5.6
A3aanKeij
Re: Using Router USB Port
Why not try?
Verzonden vanaf mijn iPhone met Tapatalk
FuturoMan
I was wondering the same thing. I really enjoy using TouchUI2 in windows and would like to be able to walk the room.
Would this work?
http://www.newegg.com/Product/Product.a ... -_-Product
Would this work?
- buttza
- FreeStyler Version: 3.6.4
I doubt the unit would be controllable from a router as the router would have no real driver for it. How would you connect to the USB unit from your computer? I doubt it would show up as an available device. You would need you buy a eDMX with Artnet available for that. This way the lighting rig connected would be available to be accessed by any control device that has it configured in the available interfaces.
