I need to create a sequence of about 3 hours. The idea is to use the moving head to travel from one point to another, that is to say, that later on to travel 3 hours, not to be in a loop.
Is it possible to do with this program? The sequence only lets me put 1 minute on "fade time"
Create very long sequence
seravifer
- FreeStyler Version: 3.6.3
- dmxlighting
- FreeStyler Version: beta
Re: Create very long sequence
can you explain a bit more?
Why do you want to do this!??
I guess using the timer control on the cue list page might allow you to have controller timed steps over any period of time but again WHY!!???
