fixture create config for 16 led par light
washtecnic
FreeStyler Version: 3.4.6
Post by washtecnic »
Hello,
I am new to this and excuse me in advance if I cant explain myself well
I need to create config a new fixture
I have done it for some other brand of 16 LED par light DMX 7 ch and it works fine but I am having lots of problem with another supplier of still 16 LED par light DMX 7 ch
channels description of par light manual is as follows:
CH1 : Total dimming
CH2 : R
CH3 : G
CH4 : B
CH5 : Strobe speed from fast to slow
CH6 : Self-propelled speed
CH7 :
0 Dimming OFF
1~50 Prog1
51~100 Prog2
101~150 Prog3
151~200 Prog4
201~250 Prog5
251~255 Sound control Self-propelled
Now in FIXTURE CREATOR of FREESTYLER I created Channel Description table as:
Ch Description Locate Deafult
1 Dimmer 255 0
2 Red 0 0
3 Green 0 0
4 Blue 0 0
5 Strobe 0 0
6 Iris 0 0
7 Gobo1 0 0
Fixture Config table as follows
goboch1 7 N.gobos 7
enabled CMY/RGB and RGB values
Red ch. 2
Green Ch. 3
Blue Ch. 4
Shutter Ch. 5 open closed 255
Strobe ch. 5 low 20 med 35 high 45
intensity ch. 1 min 0 max 255
iris ch. 6 min 0 max 255
this is my setup in fixture creator in freestyler and it works fine with many 16 led par lights 7 ch I am using, but not for this one described above :(
could anyone help me telling me how to modify the fixutre in order to make it work
if you need further details please feel free to ask me
thanks so much
mario
washtecnic
Re: fixture create config for 16 led par light
I think I am specifying something wrong on channels 5, 6 or mainly 7 :(
FreeStyler Version: 4.1.7
Post by Rod_Horning »
Did you resolve your problems?
If not, please export your fixture and post it here so that we may look at your configuration.
Also please post the brand and model of the instrument or else a link to the user manual.
FreeStyler Version: 4.01
Post by Partyman »
try changing your shutter channel to "1"
