DDM 400 & Channel 1
PizzaMan
DDM 400 & Channel 1
Hi!
I have a problem with DDM 400 with the last version of freestyler: I' m not able to assign the DMX channel one of my dimmer to a channel of the DDM 400.
The PAR on the DMX channel ONE remain controllable from the slider outside the DDM. If I do the blackout on the DDM, the light turns off, but don' t follow chaser ecc... The others lights on the channles 2,3,4 work fine.
Any suggestion?
Thanks.
Any suggestion?
Thanks.
- djSupport
Re: DDM 400 & Channel 1
erm dont use channel 1?
daantas
Hello
I think that word meant something else.
I have the same problem.
Its not channel 1 of the dmx but Channel 1 of the dmx400.
But if you have the fadertime start of the dmx400, then the problem solved.
Is the fader time off, then work channel 1 of the dmx400 not.
- Mattotone
- Android Dev (Moderator)
- FreeStyler Version: BETA
[bugreporting][/bugreporting]
- djSupport
wasn't that fixed in one of the latest beta's????
daantas
I have the latest verssie 2.96i
I think that the bug is still inside
I have already reported a few months ago in the bug raport
got a email message that it is resolved
this is not yet the case
greetz Daan
greetz Daan
- djSupport
Resend then....
- Mattotone
Works fine in the latest beta 2.97c.
(not currently public release)
- djSupport
c? hmmmm
- Mattotone
2.97c
Overridebuttons fixed in touchscreen
• Bug fixed with midi and mousecursor
• Bug fixed in color slider
• Release override in all windows fixed
• Pan & tilt up/down buttons bug fixed (changes both channels)
• Sequence name in cue fixed when added with save dialog
• Bug fixed "add to cue" always inserts on row 1
• Bug fixed in Mousepad
• Bug fixed in mousepad: ball not moving like it should when pan or tilt locked
2.97b
Some bugs fixed:
- the use of midi blocked the cursor
- delete sequences and folders
- some minor tweaks and enhancements
2.97b
Some bugs fixed:
