FX Genorator Help Needed.
Goochie
FreeStyler Version: 3.5.5
Post by Goochie »
Hi Guys,
whenever I generate an FX for some strange reason, the Pan or Tilt, which ever I'm using, suddenly reverts to 'snap' all the time when I have set it to 'Fade'
Why is this happening and how can i overcome this?
I cannot reset to fade and 'add to all steps' because i'm adding different gobo's and colours in each consecutive Fx.
is there something in settings I have missed?
thanks in advance...
Goochie.
kittmaster
Commited FS Forum helper
FreeStyler Version: 3.6.2
Re: FX Genorator Help Needed.
Post by kittmaster »
start a scene with the fade option selected, copy that scene X times, go back to each step and adjust pan/tilt as needed.
Goochie
Post by Goochie »
kittmaster wrote:start a scene with the fade option selected, copy that scene X times, go back to each step and adjust pan/tilt as needed.
Thanks mate, but that is a very long process, similar to what I have to do now, do a scene and change each individual one to Fade from snap. Takes ages
The problem is WHY is it changing every time to Snap when it was set to Fade? And how to stop it?
kittmaster
if you're copying and pasting the initial scene with the fade selected, it will copy the fade with it when you paste the subsequent steps.....which is why I mention it.
Goochie
Post by Goochie »
No mate, just using FX.
I set it to fade, create lights as I want everything then hit 'generate' it goes to Snap even tho I have set tilt or pan to fade?
Just had another look and it does it for every FX but not on Sine & Cosine??
Am i missing something here? Are they supposed to do that in those FX's ?
Post by Jan_K »
Hej Goochie.
I think you should report this as a bug or make a feature request on it.
(As I see it FX are missing a selection box for Snap / Fade)
Goochie
Post by Goochie »
have done that now Jan, cheers mate.
Lets see what happens...
