please a i need PAR 64 60w LED PAR COB RGBW fixture
thanks
Djblair
- FreeStyler Version: 3.6.3
- Twitter: None
Re: PAR 64 60w LED PAR COB RGBW
Any news on this one?
- FreeStyler Version: 4.1.7
Attached is a fixture for the 8 channel mode.
After you add this fixture to Freestyler and select it, click on the top menu item Window -> All
The following Freestyler fixture control windows will open (move them around if needed):
Lamp
Macros
Colors
Lamp
Macros
Colors
Stairville_LED_Par_COB_RGBW_8ch.pff- (43.46 KiB) Downloaded 59 times
Djblair
- Twitter: None
Rod
first of all thank you for your help BUT its not the right file
Here is a link
https://www.avsl.com/product/154.036UK- ... ic-par-can
Here is a link
Thank you for the link.
Try this one.
After you select the fixture the click on the top menu item Window -> All
The following windows will open:
Lamp
Colors
Macros (These set channel 3 to the selected function)
Freedback always appreciated.
Try this one.
Lamp
Colors
Djblair
- Twitter: None
((IS IT A BIRD , IS IT A PLAIN, NO ITS SUPER ROD !!! )))
Works fine
Works fine
