Any idea how to add a RGBWUV color in a fixture
Scartio
FreeStyler Version: 3.0
Post by Scartio »
I want to create a fixture file for the Eurolite SLS-3 and SLS-7 - both of them have RGBWUV led modules on them. In .35 version i can find a R G B W WW and A as colors...but no UV.
Has anyone tried and done this or is there a special trick? A clickable box for UV would be nice....
Regards,
Maarten
silkstg
Re: Any idea how to add a RGBWUV color in a fixture
Post by silkstg »
I have a similar issue, running lights that are RGBAW+UV.
At the moment I have the fixtures created as RGBA and then WW as white and CW as UV (I know it would make more sense to have them the other way round but time constraints were there).
Even if it were possible to select a box that changed WW to UV that would make my little brain stop pulling up UV when I need white and vice versa, but for now it is working, and I just have to remember which is which.
Post by Jan_K »
You can use custom slider.
I know that it moves the UV away from the color control panel but on the other hand in custom slider you can label the slider UV.
silkstg
Post by silkstg »
Hi Jan,
Thanks for that, will give it a go.
Kind regards
Tom
