Hello,
first of all. Thank for this great dmx software package. I am a beginner using dmx and lightning, but freestyler is realy helpful.
Currently I started using led pars and led bars.
Now my question. I try to use led bar with RGB and 8 segments. Is it possible to use the internal FX generator to fill segments of led bars? I try to build some interessing moving light
0-0-0-0-0-0-0-0
1-0-0-0-0-0-0-0
1-1-0-0-0-0-0-0
1-1-1-0-0-0-0-0
1-1-1-1-0-0-0-0
1-1-1-1-1-0-0-0
1-1-1-1-1-1-0-0
1-1-1-1-1-1-1-1
0-1-1-1-1-1-1-1
0-0-1-1-1-1-1-1
0-0-0-0-0-0-0-0
Currently I only fill all segments at once with color. Not individual.
Thank you for help.
Best regards
Stefan
Guidance generate moving lights - LED Bar & FX generator
