Is it possible to open cuelist via MIDI
pr-ra
I Use FreeStyler for: Band
Post by pr-ra »
Hello,
can you anyone help me?
Is it possible to open another cue list via MIDI?
I have several cuelists and I need to open for example cue list no. 2 and start sequence no. 3.
Starting sequence isn´t problem, but I can not open the cue list.
Thank you for the advice.
Radek
FreeStyler Version: 4.01
Re: Is it possible to open cuelist via MIDI
Post by Partyman »
yes, there are midi commands for exactly that "toggle cuelist 2"
pr-ra
Post by pr-ra »
I tried this command: "toggle cuelist 2"
but nothings happened.
MIDI starts sequence with cue what I set manually.
I do not understand how the cue list should be named
Can I have own name or it must be Cuelist 1, cuelist 2 ....
Post by Partyman »
The info I gave should allow you to change through the cuelist buttons, then depending on options selected the individual cues would fire. The is also a "Cuelist Tab"
