American DJ HyperGem
Jakke
Just started using FS
Post by Jakke »
Hi! I found some setup to use with it, but it didn't seem to work at all for me.
http://intranet.americandj.com/ItemRela ... em_led.pdf
There is the link to the manual, I don't understand all this so... I figured since I am using FreeStyler for my LED-strips, and there are files for my Martin Destroyers and one I can't remember then name of, which I can chain up in a separate run to my LED-strips later on, I figured my HyperGems should be attached too.
When I tried the settings for it I found on the forums somewhere (I googled it), nothing happened at all. There was just no input sent to it it seemed like.
If they should work with that, I would be happy to be instructed how to, but I know that was rather few channels, it seems the lights can be controlled rather advanced if you just want to.
