This is from the old forum
Wisley
I have an Entec Open Dmx Interface and try to control the Space Color Laser from JBSystem. The Problem is that the mirrows work very slow when i use Dmx. After set in an program and cut the connection it works very good. The patterns also look like shi.. with the Dmx. I heard something about that the interface is to slow for this.Does anybody have this Laser and some experience with this?
Thanks for answere
Markus, Germany
stevet
Have you tried the JBSystem with a different controller?
Wisley
No I havn´t tried. I would like to know some experience from other user, befor i´ll buy a new controller...
David
Hi Markus,
Yes it is an interface problem. I have the same problem, although with a different laser and was told by the company that the Enttec open DMX is too slow.
