Sliders don't configure. Topic is solved
Goochie
Post by Goochie »
new to IOS App, just downloaded it.
only two or three of the sliders configure to my ADJ Inno Spot LED heads?
Is there anyway to configure sliders or edit them on the App?
Pan & Tilt work, Master intensity and Intensity and Shutter work but Nothing else does???
Is that standard for the App or am I doing something wrong?
Help appreciated here guys.
Many thanks
goochie
Gennyswiss
Re: Sliders don't configure.
Post by Gennyswiss »
Do you use the iTunes app in your device?
If yes then it can be the iTunes Error 590624 which is not letting you configure this as it has already made me suffer. The only option is to fix it which you can do easily.
keanhong2
FreeStyler Version: 36.34
I Use FreeStyler for: Church
Post by keanhong2 »
what app are you using is it Touch OSC? if yes , actually there is a tutorial from FS Wiki because i just learned editing my own touch panel thru adriod App.
Return to “iOS (iPhone & iPad)”
