Connection without WIFI???
Goochie
FreeStyler Version: 3.5.5
Post by Goochie »
Hi guys, just downloaded the App from App store,
Whilst is seems to work fine at home on my WiFi network, is there any other way to connect the ipad to my laptop without WiFi or Bluetooth (Laptop has no Bluetooth)
As I play gigs without WiFi connections It would be still very useful to be able to use App remotely in these conditions.
I have read about Ad-Hoc connections from Laptop. Can I use one of these to control App on Ipad?
Thanks in advance
Goochie
buttza
FreeStyler Version: 3.6.4
Twitter: twitter.com/@buttza
Re: Connection without WIFI???
Post by buttza »
You can do ad-hoc.
Once you create a network on your laptop your ipad should connect to it. Check that your firewall settings are allowing the application to get through .
Return to “iOS (iPhone & iPad)”
