Hey,
I'm using Freestyler with some LED Pars for my office.
I've got Freestyler in my startup folder so the programs starts when my PC does, but it would be even better if it could also automatically start the cuelist the does the color changing for the pars.
Is it possible to set a cuelist to automatically start?
TIA, Matt.
Help - Start Cuelist on Program Load Topic is solved
- FreeStyler Version: 4.01
Re: Help - Start Cuelist on Program Load
under the file menu (edit) there is a button to save startup values. I dont think you can run a sequence but you can have the lights to come on to certain values at startup
MattIPv4
Ah poop. I've set startup values, but I was hoping I could start a cuelist, either in the program or as a program flag.
