Freestyler Multiplay Utility
Android Dev (Moderator)
FreeStyler Version: BETA
Post by Mattotone »
Thus utility will allow you to control freestyler using the popular multiplay app
http://www.da-share.com/software/multiplay/
This is different from the midi/loopbe implementation we have used in the past, this app will allow direct control without the need to setup midi rules and gives the added benefit of being able to dynamically load sequences into the cue list by sequence name.
as an added bonus the utility can be accessed via command line and therefore is accessible by many other programs including windows schedule tasks, Windows Shortcuts, Home Automation software , batch scripts/powershell scripts. basically any software that can call an exe
FreestylerConsole.rar
(391.7 KiB) Downloaded 271 times
Includes manual and utliity
lobelzar
FreeStyler Version: 3.45
I Use FreeStyler for: Theater
Re: Freestyler Multiplay Utility
Post by lobelzar »
Bonjour , merci mais comment utiliser freestylerconsole.rar
merci a toi
