Cameo Par 56 (CLP56RGB10PS) Topic is solved
Constey
Post by Constey »
i'm looking for a fixture for the cameo Par.
The DMX Table is:
CH1 000-255 RED (0-100%)
CH2 000-255 GREEN (0-100%)
CH3 000-255 BLUE (0-100%)
CH4 0-255 Master dimmer (0-100%)
CH5:
0-16 No function
17-255 Strobe/Speed Adjust/Sound Sensitivy Adjust
CH6:
0-31 No function
32-95 Colour mixing
96-159 RGB colour change
160-223 7 colour change
224-255 Sound activation
I've tried with the fixture creator, which works well for the basics (1-4). But I dont know how to make the correct sliders for Channel 5 and 6.
Can someone lift me up with this?
Thanks,
Constantin
Cameo PAR56 (6CH)neu.pff
(6.69 KiB) Downloaded 25 times
Re: Cameo Par 56 (CLP56RGB10PS)
Post by Jan_K »
Hej Constantin
Channal 5: You have done that correct though I would have set off = 0 instead of 16.
The problem is that channel 5 is used for more functions and there you need to figure out what works best for you when you are operating the fixture.
You can make some macros which indicates speed.
This is a bit the same with channel 6.
Make some macros for "Off", "Color mixing" ,"RGB color change", "7 color change" and "Sound"
The tricky thing comes in if there are more functions in the ranges.
Meaning:
Hopefully it is so that it doesn't matter if you set the ch6 value to 32 or 95. The color mixing will be the same. In this case you only need one macro for each of the functions on ch6.
Worst case is that the color mixing are changing due to the value so 32 will give you one colormixing, "40" an other, "60" again an other and so on.
If this is the case then you need to figure out where it shifts and make a new macro each type.
You can eventually have a look in the attached fixture.
Camero_PAR56_jan_6CH.pff
(23.91 KiB) Downloaded 31 times
Constey
Post by Constey »
Thanks for the Hint with the Macros, i've added that when channel 6 is 0, channel 5 is also set to 0 - otherwise it would start to strobe.
And I've added a Macro for Strobe directly.
Testing it at the weekend then i'm gonna share the pff here.
Post by Jan_K »
You are right.
I missed that one. Channel 5 need to be 0 when you turn off the color macros.
fabi_tec.de
FreeStyler Version: 3.4.6
Post by fabi_tec.de »
Constey wrote: 04 Aug 2016, 19:48 Thanks for the Hint with the Macros, i've added that when channel 6 is 0, channel 5 is also set to 0 - otherwise it would start to strobe.
Hey, i tryed all but i dont find any way to bring the light to work. Can you please share the newest .pff file
Thank you very much
