Fixture Láser Big Dipper Azúl Boca Doble M500b/2
santiolivela
Hola que tal amigos? Soy nuevo aqui! necesito el fixture del laser doble boca azul big dipper M500b/2 alguien que lo tenga o pueda crarlo! Me serviría de mucho un saludo a todos
andresguarindj1
- FreeStyler Version: 6
DJFrancoDeLaCruz
Re: Fixture Láser Big Dipper Azúl Boca Doble M500b/2
Como se configura con el fixture creator 6.8 ???
- FreeStyler Version: 4.1.7
The attached fixture is for 12 channels. It was created with Fixture Creator 6.9, hopefully it will function correctly in your system. It should control both of the instruments you posted.
Use the standard Freestyler sliders in the upper right hand corner of the Freestyler window to control all functions. (the RESET function is also available in one of the Freestyler windows or icons)
The fixture is very generic so you will need to have the chart with the DMX channel descriptions and values. If I have some time I will try to improve the fixture definition - or perhaps another user can provide a more user friendly fixture.
Seven_Stars_Laser_generic_12ch.pff- (16.39 KiB) Downloaded 77 times
