Has anyone found a profile for a Spot lyre : Led Spot 90w from Tongfast HK LTD (China) ? I have been looking and downloaded the new fixture list and cant seem to find anything like it. I know its all backwards from a normal moving head light but I'm not sure id be able to get the profile set up right. here is the pdf file dmx info and if anyone could point me in the right path thanks for your help.
Fixture for Lyre Led Spot 90w from Tongfast HK LTD (China) Topic is solved
maconly34
Led Spot 90w.pdf- (1.16 MiB) Downloaded 91 times
maconly34
Re: Fixture for Lyre Led Spot 90w from Tongfast HK LTD (China)
I have found a similar lyre : Varytec LED Easy Move Spot90, but no fixture.
thank's for your futur help
maconly34
Hello
Je fais les requests et les answers !
Bon après un tuto et beaucoup de temps, je viens de créer ma première fixture !
Les photos des Gobos et couleurs sont les vrais puisque je les ai tous pris en photo
puis recadré, retouché...
Donc voilà ma contribution (peut-être à copier dans le forum adequat ?)
Après install, vous la trouverez dans le dossier MC2concept
Led Spot 90W.pff.zip- (39.31 KiB) Downloaded 119 times
