I's sorry if this is a repeat question or has been previously answered, I did spend a considerable amount of time searching but was unable to resolve,
I've been asked to do a White Collar boxing event, and have 3 LED par cans and 2 Stairville MH250 Moving heads, my intention was to fire off a blue sequence for the blue corner win and a red sequence for a red corner win using a key board short cut.
I have created all the sequences with no problems, and set them in Cue. The problem im having is that the Colours don't change from cue to cue.
i.e when i tap key 1 for the blue corner the pattern on the moving heads is fine, but the the lights stays red, and when i tap key 2 for the red corner the pattern works again but the colours stay red, i would like them to fully change to suit the winners, and also to do a third cue when the boxers are coming into the ring
Sorry if this sounds confusing.. but any help would be really appreciated
Colour Issues in Cue Playback
DMAC
- FreeStyler Version: 3.6.3
spud1511
- FreeStyler Version: 3.5.7
Re: Colour Issues in Cue Playback
Make sure the colour channels you wish to change are showing as 'snap' (and not 'off') for each affected sequence.
