Two questions seek help
xixi
Just started using FS
FreeStyler Version: 3.2.1
Post by xixi »
1. I have two Sequence's, one is gobo(1.chr), one is Pan/Tilt(2.chr).
Can only loop all sequences .
Or in CUE, two may also move .
Saves two sequences is a Submasters document, like aaa.fcf, when replay, can only move in 1.chr or 2.chr.
How only then can in replay Submasters, simultaneously move these two sequences, but is not the link.??
2.The present is five Submasters, four pages,when operation easy flustered .
If is 10 Submasters and 2 pages, that was more convenient .
tendril
Has mastered Fixture Creator
FreeStyler Version: 2.96j
Re: Two questions seek help
Post by tendril »
Are your sequences saved as transparent and do you have the unused channels set to off (red)?
You may find that reading this thread will help you
Desktop:
Athlon 1.8GHz | 512MB RAM | WinXP (Updated)
FS: 2.96j
Laptop:
Pentium III 750MHz | 256MB RAM | WinXP (Updated)
FS: 2.96j
Both running with Enttec Pro
