Dear all,
it is still not clear to me how I can save the Color Presets (for 3 channel RGB),
so I don not loose them and be able to reuse them in the future.
Is there a specific file that these values are stored in ?
And what if I need two or more different Color Preset sets
(each set would contain 10 Preset assignments)
How Color Presets (3 channel RGB) are saved ? Topic is solved
