I just purchased two Lightmaxx Dj scan used LED.
I installed under Windows XP 3.6.3 freestyler with an open box dmx Enttec home Electroconcept. CDM drivers 2.12.14 to the case.
The problem dice connecting Dj scan the box and launch freestyler with no fixture, the scan is random motions on all channels (7ch)
I test my cable with DMX scanner working perfectly bug free. Under freestyler with the USB Box - DMX I random movements.
Will someone meet this problem?
Thank you for your help, sorry if I posted in the wrong section I do not know the good forum
Sorry for the translation I got help from google, I only speak french
[resolved] bug Lightmaxx Dj scan LED Topic is solved
Scofield57
Scofield57
Re: bug Lightmaxx Dj scan LED
Hello,
I solved my problem by equipping wireless dmx.
And since I have no more worries.
good continuation
good continuation
