This is from the old forum
Kikabyte
Ok, so my old USB - DMX device broke, so i ordered the above off ebay on monday and its come through this morning. I installed the drivers, and loaded freestyler 296 setting the Interface selection to Afterglow. But all I get is the message 'Error Creating Output Thread'. Does anyone know of any problems with this device with freestyler? I have tried all sorts of settings with no success.
I have a gig on Saturday, and I have to have a working USB - DMX device. (That also works with Vista), so any idea's I would really appreciate them!!
Id send an email to raph he is normally very good at replying quickly and should be able to offer you some advise if not a fix.
Hope you get this sorted before sat.
kind regards
Kikabyte
Brill, I'm really struggling. I've tried everything, can't seem to get anywhere!
Regards
Chris
Kykabite
Ok, for the benefit of other users, I also emailed the support at Nextec, and receieved a super fast responce, to explain that there was an issue soon to be corrected by Raph. In the mean time Freestyler should work if Enttec Open is selected. Top support from Nextec. Well recomended.
Regards
Chris
lj_raph
Hi All
Could you check if the file "Threading.dll" can be found in the windows\system32 folder?
Best regards
Kikabyte
Yes, Threading.dll is in the system 32 folder.
Nextec
I will be sending Raph an updated driver shortly that should fix this problem.
The new driver also fixes a problem when running on Vista as well.
Richard
Next Generation Technologies
Matt
Thanks Rich for Looking out!
Buster
I have the same problem as soon as i enter the afterglow as my interface controller freestyler closes down when will this be fixed ?
have you tried selecting the open dmx interface?
Afterglow Aurora-2 PC DMX Interface - HELP Topic is solved
GreggyB
Re: Afterglow Aurora-2 PC DMX Interface - HELP
Hello everyone,
Did the issue with the Afterglow drivers ever get resolved - did a new FS/afterglow driver get issued?
I am using the Enttec settings with my Afterglow Aurora-i but am getting some unusual behaviour and wonder if it is because it isn't using the proper Afterglow setting.
Clutching at straws really but you never know ....
Regards
Greg
Regards
Greg
nextec
I delayed issuing the new driver to Raph while we fixed an issue with windows Vista and assed support for our new Pro interface.
This is now all sorted and a new driver should be emailed to Raph in the next few days hopefully to sort this issue once and for all.
Richard
Richard
ukwolfman78
i seemed to have lost the software to my Afterglow Aurora-2 can anyone help
Moose
uk wolfman did you manage to find the driver as i have the same problem
- dmxlighting
- FreeStyler Version: beta
Google is a brilliant tool!
Although I don't have the drivers for you I belive that you can get them from the guy on this site....
http://www.evl-design.com/support.html
Onge
Now why did I not think of using Googledmxlighting wrote:Google is a brilliant tool!
