How can i get cues to run auto. after each other Topic is solved
Djsynystr
Post by Djsynystr »
after i make some shows is there any way to have them play in an order one after the other on there own. like if i put 4 cues in the cue window 1 want them to play on there own through the differnt shows i put together while dj'ing. i did a few searches and found nothing. i hope i explained it right. any help would be greatly appreciated. thanks in advance.
tendril
Re: How can i get cues to run auto. after each other
Post by tendril »
In the cue window (fast cue switcher) click the setting icon (file with a cog) and choose 'loop all sequences'
Djsynystr
Post by Djsynystr »
YOU ARE THE MAN! i have been bangin my head since i got this program on how to do it. Thanks !
satalog
Post by satalog »
FYI,
i can't seem to get the "Loop all sequences" feature to function in V3.0.1. I have now downgraded to 2.96J and it works fine.
