Hello Folks,
I am using the last version of FreeStyler.
The Interface i am using = Sunlite 2006
The problem i have is that FreeStyler Crasch afther a few minutes or in about 1 hour.
The whole screen is then frozen ( see attachment )and i get a popup message that there is a problem with freeStyler.
When i close FreeStyler and restart the program, it wil work shortly and the problem is back.
I have Un / installed the 64 Bit USB driver(s) i need for Windows 10. The same problem still exist.
I have tried to instal FreeStyler on Windows XP 32 Bit, same problem.
When i use the original program Sunlite, there is no problem.
Your help wil be appriciate.
Regards,
Edwin
FreeStyler Crasch in Windows 10 64 Bit Topic is solved
- FreeStyler Version: 4.01
Re: FreeStyler Crasch in Windows 10 64 Bit
Must be something with the driver for your interface. I use Freestyler on multiple windows 10 64bit PCs with no crashing
