Where do you set the chanel like if Gobo 1 is from 0-25 do you set it at 0 or somewhere in the middle? I need a bit of help here. Thanks Mike http://www.directsound.com
P.S. I also need help with transparent cues!
Where do you set the chanel#
- directsound
- FS Video Tutorials
- FreeStyler Version: 2.96j
- Mattotone
- Android Dev (Moderator)
- FreeStyler Version: BETA
Re: Where do you set the chanel#
any where within the range, but being in the center, is best because dmx is not always accurate and can be a couple of numbers up and down of the value you want.
- directsound
Great, except the dimmierI take it. I have had nothing but trouble with my American DJ Accu Spot II's,Chauvet LED-RAIN56's, and Martin Mania SCX 500 6 or 8 CH the stock profile didnt work with the visulizer so I HAD TO MODIFY it and I am still having a bit of trouble. Thanks for the feedback Mike http://www.directsoud.com
