Hi all, hope someone can help, i have made a sequece with 4 lights, an impossibled, a miracled & 2 LED Quadrabeams, and it works perfectly when i run it through the sequence editor on a loop
when i add it to the cue list it goes once then messes up on the loop
basically the first run through works perfectly on sound to light , however when it goes into the second playthrough of the sequence (only in the cue window not the sequence editor) the Impossibled &the 2 quadrabeams become unresponsive, if i click stop & play t again though it works the first time again but not after that
some lights not responding sound to light after first run of sequence
jimmyxtreme
