Hi Guys,
I wonder if anyone could spare some time to help me with a project.
I've got the following LED decoder: http://www.ebay.co.uk/itm/151824745044? ... EBIDX%3AIT and x10 of these LED strips: http://www.ebay.co.uk/itm/261698045425? ... EBIDX%3AIT
I'm trying to create sort of a grid system that can go in time with music or set scenes.
My issue is, I have no idea how to add/create a fixture for the decoder in Freestyler and get it to work so each of the strips could flash different colours or same colour on a number of strips. Something similar to this: https://www.youtube.com/watch?v=bxc3bZH_bCA
I've managed to create a 3 channel fixture for a couple of other single output decoders however this decoder I am totally lost.
Thank you for any advice or help in advance it's much appreciated.
30ch LED decoder and LED Strips Topic is solved
danmcr
- FreeStyler Version: 3.6.50
danmcr
Re: 30ch LED decoder and LED Strips
P.S. sorry if this is the wrong place to post such topic.
- FreeStyler Version: Beta
Hej
I have moved your topic.
If you have made a 3 channel RGB fixture then you just set the total channels to 30.
Enable RGB segments.
Configure it to 1 row 10 segments.
And fill in the channel numbers for the segments.
danmcr
Can I just say thanks for your help. I'm finally up & running. Next step getting them to do something fancy with music!
Fred D
- FreeStyler Version: 3.6.4
Do you have a fixture file you can share? I am not getting mine to work. I have 30 channels selected but my issue may be that I'm trying to use 10 rows with 3 channels each? I am not sure.
- FreeStyler Version: 4.1.7
Fred D please export and upload your fixture file so that we may look at it.
danmcr
It's been a while since I've been on the forum.Fred D wrote: 05 Dec 2017, 16:48 Do you have a fixture file you can share? I am not getting mine to work. I have 30 channels selected but my issue may be that I'm trying to use 10 rows with 3 channels each? I am not sure.
Did you get sorted?
Daniel
molotow
- FreeStyler Version: 3.6.51
Hi Guys,
some time ago i have found the fixture you are talking about, someone else has uploadet it in another thread. I hope, he or she wont be mad if i share it with you.
Just take one fixture for each LED-stripe you are going to use and adress them in a row.
peace.
peace.
