Sequences - How to restore to first scene on Stop
CaptainU
I Use FreeStyler for: Band
Post by CaptainU »
Very quick question with hopefully a simple answer.
I run sequences using the Sequence play buttons > and run them one at a time (so next sequence stops the previous).
Question: How do you make the Sequence start at Scene 1 again the next time it's played? At the moment it starts at the scene it was stopped at previously.
Thanks in advance!
FreeStyler Version: 4.01
Re: Sequences - How to restore to first scene on Stop
Post by Partyman »
In the Cue window at top left click on gear then select "always start with first scene"
CaptainU
Post by CaptainU »
Thanks very much Partyman.
You know, I should have tried that option! For some strange reason, whenever I looked at it I was reading it as meaning "Always start with first Cue"!
Brilliant!
