Shutter Effect with 3 Channel Fixture
abluem97
Post by abluem97 »
Hey Guys. I understand that this question is pretty amateurish. That's because i'm a total amateur.
I have a 3 channel DMX 512 Decoder with a simple LED strip hooked into it. I have the channels set up simply as:
1 - Red
2 - Blue
3 - Green
I've come to grips with the fact that the decoder does not allow for a true strobe effect (which is ridiculous because the $12 wifi controller that came with the strip does strobe.) I did set up a sequence to change colors really quickly though and it does create a pretty close strobe effect.
However, what's really baffling me is that I cannot get the shutter to work or the lights to turn off at all! I realize that the shutter should be set up on a separate channel, but the decoder is only 3- channel. I feel like there has to be a way to do it regardless (or at least simulate the effect.)
Turning the lights off should be a pretty simple function right? Am I missing something simple? Any help is greatly appreciated. Thanks for your time!
Re: Shutter Effect with 3 Channel Fixture
Post by Jan_K »
Hej
I just had a look and you are right. It looks like Freestyler don't use the shutter panel when only the RGB channels are used.
abluem97
Post by abluem97 »
Jan_K wrote:Hej
Thanks for responding Jan. Do you know of any work around for this? I find it hard to believe that there is no way to turn the lights off/on through freestyler. If not with the shutter panel then using some other method??
On/off seems like it should be a pretty straight forward function regardless of how many channels there are...
buttza
FreeStyler Version: 3.6.4
Twitter: twitter.com/@buttza
Post by buttza »
I remember asking for this a while back as a feature request. RGB Virtual Channel/Shutter so that you can fade segments on LED bars that are RGB segmented etc.
Post by Jan_K »
Well it is still marked "under consideration" and it has been that for a while so I don't think that he is going to make it unless it gets a lot of focus from our site.
http://www.freestylersupport.com/bugs/view.php?id=259
buttza
Post by buttza »
Well I hope it comes through. Would be useful.
