Disable previous cuelist first not working!
Ioka
FreeStyler Version: 3
I Use FreeStyler for: Band
Post by Ioka »
the function "Disable previous cuelist first" ist not working. Everytime i have a sequence playing inside a cue and i change the cue through the cuelist buttons the slot in which the previous sequence was playing get played inside the new cue.
So i have to manually stop all sequences before i can change the cue.
What am i doing wrong? And is there a function to stop all sequences inside a cue from playing?
Thanks! :fs:
spud1511
FreeStyler Version: 3.5.7
Post by spud1511 »
Because it sounds (maybe I'm reading it wrong?) as though you have asked it to disable previous 'cuelist' first. A cuelist being the list of cues not an individual cue within that list.
Starting a new cue (from the same list) should not stop you running the previous cue, or even multiple cues from the same list. That would instead be the option in freestyler preferences of 'allow multiple cues', or whatever it was worded as along those lines in the settings.
Edit.. Sorry think I did read that wrong, if you understand what I was saying and that's not what you meant in OP then it may be time for a bug report.
