Cue Labels?
- Just started using FS
- FreeStyler Version: 3.5.4
Cue Labels?
I can connect to the Freestyler PC program thru the Android app, however my Cue Button labels are not populating. The sequence labels are though. Am I missing something?
- Mattotone
- Android Dev (Moderator)
- FreeStyler Version: BETA
Re: Cue Labels?
no your not missing anything,
its a strange bug im unable to solve or reliabley replicate to put a bug request into freestyler., but it usually happens on slow connections or slow pcs.
the app sends the commands but freestyler appears to ignore it and not send the response.
- FreeStyler Version: 3.6.4
Re: Cue Labels?
Hello.I Have same problem.Don`t see the cues,but blackout and freeze are working.what can i do?
Thanks !
Thanks !
