Just received my par/uplight cans from Amazon http://www.amazon.com/GBGS-Super-Bright ... B00QLPHJIE and created a profile for them. These are the 8/5 channel pars with 7x10 watt RGBW LED. There are a few others listed I presume are Alibaba under different names. They look pretty worthless in 5 channel mode, so I created an 8 channel profile with macros for the tricky channel 6 modes and corresponding Gobos for the Static Color & Auto Color Changing/Fade In/Fade Out/Jump Change. Let me know if there was anything you wanted to add. I wish there were a way to dim them in "Sound Activate - Jump" mode because they are BRIGHT. I frequently busk with an override in sound active in my own show. These are almost too bright for uplights in that mode. Great for stage use though. Enjoy.
Update: tested, and edited the photo so it's a pretty transparent GIF 60x60. April 28,2016
http://ecx.images-amazon.com/images/I/41oN3AhH5qL.jpg
Generic Chinese 8ch 7*10 watt RGBW Par "GBGS" brand
NaughtyMonkeyDJ
GBGS instr.pdf- (1.78 MiB) Downloaded 301 times
GBGS_8ch_RGBW_PAR.pff- (18.94 KiB) Downloaded 366 times
NaughtyMonkeyDJ
Re: Generic Chinese 8ch 7*10 watt RGBW Par "GBGS" brand
Other lights that may be similar:
GBGS
http://www.amazon.com/GBGS-Channel-Ligh ... B00QM3CNN6
Eyeyourlife
http://www.amazon.com/dp/B014L0OLQI?psc=1
TSSS
http://www.amazon.com/TSSS-Background-L ... s=tsss+LED
GBGS
Eyeyourlife
TSSS
NaughtyMonkeyDJ
I also have a question: after testing this, the master dimmer fade in/fade out works perfectly. I don't know why!!!
Does the master control use the word "dimmer" in a channel to tag it into the master? Confused.
NaughtyMonkeyDJ
I have received also from Amazon the "Eyeyourlife" similar fixture, which has a slightly different profile!
Attached are the .pdf for this fixture, and the Eyeyourlife modded .pff
Eyeyourlife instructions_1.pdf- (841.5 KiB) Downloaded 222 times
Eyeyourlife_8ch_RGBW_Par.pff- (16.26 KiB) Downloaded 206 times
rudylara1970
These look to be pretty much what I have, so I'm hoping this will help - how do I incorporate what you've created into FS?
