External Control (TCP / API) Topic is solved
SFX Group
Post by SFX Group »
Hi all
We are new here, i notice this software has external control, where would i get more information for the TCP, server or API?
We are trying to use HTTP commands to control the software from HomeSeer.
Many Thanks
Ashley
SFX Group
Re: External Control (TCP / API)
Post by SFX Group »
Hi
Can i assume this software no longer supports remote control via TCP?
Many Thanks
Laudrin
FreeStyler Version: 3.6.49
Post by Laudrin »
Hi Ashley,
I suppose you do not still read the forum posts after two years without an answer, which seems to be a problem of this forum. But maybe someone else will find this answer and find it useful:
The documentation of the TCP protocol is found in the FreeStyler directory under Documentation\Sendmessage and TCPIP.pdf
So, it still works. :-)
